Re: charging system
can buy here at Iboats about 35 dollars..........make sure ALL elect connections are clean and tite....never disconnect battery with engine running to see it if is charging it will kill rectifier.....when rectifier is bad most time the tach wont work, but not always.....your is probably rectifier as your are thinking..........good luck
