Faztbullet
- Joined
- Mar 2, 2008
- 15,930
Please fellows do not waste your money on the "off brand" grey fuel hoses. Buy the Merc or Brp hose and bulb... These are packaged "alcohol" resist but only the liner inside line is resistant. Below is pictures from yesterdays repair on a buddy of mine's BFL boat.. He was having: surging problem,bulb not wanting to pump up and shutting down. I pulled the bulb and found brownish debris in check valve, looking into line I found the "liner" was breaking up due to ethanol fuel. He tows the boat with near empty tanks and has to take what ever fuel is at tourney site. By the way this hose was installed at a "dealer" a month ago when he had compressor fail during a tourney. I replaced entire hose with 3/8 MPI Marine grade fuel hose and new "Merc" bulb, replace the water seperating filter and replaced diaphram in fuel pump. A test run was performed a is fixed!!!!
PS for a great rod log onto: http://www.bigsowbaits.com/citrus-stick.html
