I see many come to the forum asking if they can get significant H.P. gains cheaply. The answer in a word is, no. Swapping intakes and carbs might help in your street car but have almost no significant gain in a boating application. In fact, an additional 20 or 25 Horse Power in a boating application simply will not yield significant increases in low end torgue or top end speed for the vast majority of boats. If you want to see real gains you need 50+ H.P. to even notice the difference and that doesn't come from bolt on mods.
Can you get more H.P. from your existing engine? In most cases yes, but it really means pulling the engine and doing some major work. Different heads, different cam, having the engine borded, etc. Again, nothing easy or cheap.
Also keep in mind that in most cases the outdrive has a maximum H.P. limit and you REALLY need to check to make certain you don't exceed it. Also note that if you do build your existing engine it will almost certainly require a higher octane rating for gas and in todays world that means more money to fill up.
Point to all of this? Don't waste a bunch of dollars only to be disappointed in the results.
