On-Going Problem. For over a year the check engine light and overheat alarm has gone off after 3/4 of a mile at WOT. Originally posted and given the advise to look into fuel restriction. Over winter cleaned/rebuilt entire fuel system to the pump. Same problem this year. Take to mechanic, he says overheat-rebuild water pump, replace grommets on water tube, System check on temp sensors, Flush, Flush, Flush-On-Going Problem. 96 Johnson 150, J150ELEDB.<br />Is there anything we are overlooking. Next option pull the heads?
