michiganmarty
- Joined
- Aug 12, 2003
- 62
My brother's boat is a 1999 StarCraft 196 FishMaster with a 115 Merc. The engine Rpms are at 5900 - 6000 rpm according the tachometer on the dash.
The motor supposedly has the prop that was intended for the boat, so we're not sure if the on board tach is reading accurately - so where do I purchase a tach that will work on an outboard motor?
I have two automotive tachs and neither will work. The old analog (with a wire clamp) seems to work, but does not have a scale high enough (the needle runs out of scale).
My digital wire clamp tach won't work due to the close prximity of the other wires interfering with the signal. So that doesn't work either!
