check firing?
noah4009
What is the easiest, safest way to check if a cylinder, coil or plug is firing?
slasmith1
Re: check firing?
pull the plugs, connect the plug to the plug wire and ground the other end to the block, turn over motor, watch for spark
noah4009
Re: check firing?
Now I touched a plug wire to a car while running and, yep I got lite up. Will I get shocked if I hold the wire? You said the end of the block. Meaning the part under the head?
slasmith1
Re: check firing?
anywhere on the block just needs to make contact with ground
noah4009
Re: check firing?
Safest way? How do I hold wire or what do I hold it with? Without getting zapped
fishrdan
Re: check firing?
YES, just ask my buddy who held up the disconnected coil wire and asked "is this important" right when I was cranking over the engine. :D Yes, I could have not cranked over then engine, but I couldn't help myself....
When you remove a plug wire 2 things will happen,
-the engine will run different if it's firing
-the engine will run the same if it's not firing
Oh forgot the 3rd, if you are the best path to ground, you will now be the spark plug...
noah4009
Re: check firing?
Did as you guys said. I just used a piece of cardboard to hold. Both plugs are firing. Plenty of spark.
Thanks for the help
