Re: check vales into each cyl
Hey, the check valves are in the intake manifold and will be screw ins. the nipples in the clys are just pressed in and just have a jet inside the fitting. I remomoved the cyl. fittings by tapping the fitting with a screw driver at differant angles then pulled them out with vise grips, very easy. I had 2 other nipples on the cyls that were clogged, it took carb cleaner and air commpressor to free those up, be patient it takes time. Good luck
