Checked the boat speed today, with the GPS
204 Escape
Ensign
Our boat is a 2006 LARSON 204 Escape F/S Deck boat. It has a 5.0 carburated engine, with a Alpha One unit, and a 19 pitch aluminum prop. The boat is 20'-1" in length. The brochure says that it weighs 3,100 #'s Holds 50 gallons of fuel. Has a deadrise of 17 degrees, Transom angle of 14 degrees. It is a modified "V". It is a 220 h.p. engine.
According to the GPS, the following notes are what it read today, on the water, with a full tank of fuel, and "4" people. Weight of the people is approx. 496 #'s.
Speeds/rpm's, and speedometer speeds were as follows:
RPM's GPS Speed Speedometer speed
3250---------------- 32 ---------------- 36
3950---------------- 37 ---------------- 40
4900---------------- 45 ---------------- 50
I was wanting a little more top end. We pull a tube with the boys in it, for a combined weight of +/- 190 #'s
At one time, it was suggested that I go to a 18" pitch, 4-blade unit. NO SPEED was mentioned, so I don't know what to expect out of it.
Any suggestions ??
Thanx,
204 Escape
Silvertip
Re: Checked the boat speed today, with the GPS
If you are at 4900 at wide open throttle with a 19P prop, you would over rev with an 18. The correct prop is one that allows the engine to operate at the high end of the manufacturers recommended wide open throttle rpm. Speed will be whatever that prop provides. More pitch you lug the engine. Less pitch your over rev. Happiness is in between.
junior1113
18p 4 Blade Will Out Perform A 3. U COULD EXPECT A BETTER HOLE, SHOT SLOWER PLANE SPEED, BETTER MID RANGE FUEL ECCONOMY, AND WILL PROB BE THE SAME. IF TOP END SPEED IS ALL YOU WANT HIGH PERFORMANCE 3 BLADE USSUALY IS BEST
hwsiii
Escape, I found the boat to weigh 1,800 pounds instead of 3,100 pounds and the gear ratio to be 1.62 and a recommended RPM range of 4,400 to 4,800 RPM, if this is wrong please let me know as my numbers will be off. With using the following numbers I found your boat should be using a 19" Pitch 4 blade propeller and you should be turning right at the top of your RPM range at about 48 MPH and the 4 blade will help with hole shot, tubing and your mid range cruising speeds and should bring your prop slip down from the 17% it is now. Here are my numbers.
Boat and Motor
Prop Picker
Prop Change
H
