Re: checking a rectifier
Been retired for 1 year after 45 years in the electronics business. Can't believe how fast you can go brain dead.<br /><br />Most ac voltmeters read rms voltage (root means square.....square root of (1st element squared plus 2nd element squared plus 3rd squared... thing). Fancy term for the same heating effect for the same voltage in dc.<br /><br />To convert from rms to dc you multiply by the square root of 2 (1.414) to get the peak value, then start subtracting your losses..... half wave vs full wave vs bridge recification (your diodes we're talking about here) diode drops, source impedance (resistance), line losses and all. The result is the dc that is sitting on top of your battery when your engine is doing a couple thousand rpm's. <br /><br />In short your 26 vac is great. Your alternator is alternating like it is supposed to.<br /><br />Problem looks like your diodes are defective. Doesn't matter what's wrong.....they just aren't getting 14+ ish volts dc delivered to your battery like you are supposed to have.<br /><br />Radio shack rectifiers may seem like a good idea, but you are in a marine environment and you need to have your connections sealed and your diodes sealed against moisture and all. You need to get the right type to get the necessary voltage (half wave, full wave, or bridge type rectifiers)<br /><br />The $25 to $40 may be cheap in the long run. Bite the bullet and go for it.<br /><br />HTH<br /><br />Mark
