checking compression
44sparky
what is the proper procedure for checking compression on a rope start(rewind) older outboard? car engines require a wide open throttle to get the highest reading, as well several strokes are necessary, each one higher than the last. true of outboards??
S.T. Marine
Re: checking compression
Take all the plugs out. Attach the comperssion tester. Pull the motor over several times untill you get your higest reading. Do it to all of the cylinders. ITs very easy.
44sparky
thanks for the advise but still wondering whether having the throttle open when checking compression would give a higher reading. taking in a full charge of air would seem to indicate a higher reading. thanks.
S.T. Marine
Nope has nothing to do with it. Compression reads in the cylinders not out of them.
44sparky
yeah, i guess 2-strokes are different, i know on 4-strokes, they recommend open thottle plates for compression check. thanks again.
