gpfishingdude
- Joined
- May 1, 2012
- 538
I installed the new rectifier on the 50 horse motor and would like to find out if the motor is charging the battery now. My controls are simply neutral-forward-reverse. It is nearly impossible for me to get to the battery with the boat in the water to test the voltage. Will I be able to check this with the muffs on in the drive way or would I have to rev the engine too much to see if it is charging? Keeping in mind that if I try to check it at the dock it would be in gear if I try to rev it up.
