My tach is not working but when I turn on the key the tach goes to zero (from its normal 1000 shut off position) like it should. I was told to check my pulse wire to make sure I am getting signal from the engine. I have a 1998 johnson v4- 115 hp and was told that the grey wire on the back of the tach is the one to check for impulses. Wha is needed to check the pulse and what should the readings be on a volt meter?
