OptsyEagle
- Joined
- Sep 13, 2006
- 1,359
So I am planning on changing the impeller on my 1961 5.5Hp Johnson and decided to remove the starter before I remove the powerhead. Once off I remove the little cover for the hole that allows you to check the points on this motor without removing the flywheel. I was wondering if anyone knew what the correct procedure was, since it is difficult to see where the rub bar of the point is on the cam. Would one just attempt to center the point opening inside the hole and assume that is close enough to the "set" point for this?
