Re: Checking the Spark Plugs
Hi, Tommo.<br /><br />Remove the spark plugs. Reconnect the one you want to check to the wire and hold it against the block (CAREFULLY
)while you spin the engine or have a helper spin it. You should see a hot, blue or white spark.<br /><br />Good luck.
