Checking Trailer Brakes
IVAZ
Hello fellas,
My boats trailer is a tandem axle and it?s equipped with drum surge brakes. Is there a way to check that the brakes are working properly? I haven?t ever needed to slam the brakes but if I ever do I would like to know my brakes are working correctly. The system seems to be in good shape (holds fluid and there is no rust in the reservoir). So, short of panic stopping how can I test them?
Thanks for any input you may have.
iBrent
Re: Checking Trailer Brakes
Here's a test I've done a few times on accident!
Disconnect the electrics from your vehicle, then try to reverse. Without the blue wire sending the reverse lockout signal to the surge breaks, your vehicle will be pushing up against the surge coupler. If you can't back it up, then the brakes are working.
IVAZ
Brent, thanks for taking the time to respond.
I don?t know if I can do your test. I think drum surge brakes free wheel in reverse. I don?t have a blue wire on my trailer either.
iBrent
Ooops. Sorry, I missed the drum part. Mine are discs and definitely lock in reverse without the harness hooked up or the reverse lockout pin inserted.
jeffnick
Jack up the trailer one side at a time and have a buddy spin the wheel while you do this.
You can also engage the emergency stop by pulling the chain/lever, then trying to move the trailer. However, sometimes this can get you into more trouble than it's worth.
IVAZ
That seems simple enough. Thanks for the diagram.
