Checking vent on gas tank
rhcotton
I have a twelve gallon gas tank in my bass boat. It is mounted in the hull of the boat under two access covers. What is the best way to find out that it is vented properly. All help is appreciated.
JB
Re: Checking vent on gas tank
Moving to Boats.
delta breeze
RH,<br /> If you can locate where the vent comes throught the hull.Remove the hose at the fitting,remove your fuel ,and blow low psi. shop air or your air through it it should be easy to blow through.if not check for any ostructions. Good luck<br /><br /> Delta Breeze :cool:
