Cheetah 180V (1984) or similar outboard conversion
Muskytek
I’m looking at an 84’ Cheetah 180V as a potential project hull.
It will be converted from a V8 I/O to an outboard. A V4 OMC outboard
What might I expect as far as surprises with its performance? I noticed the rear has a fairly pronounced hook molded in and I don’t see that much on outboard boats.
At 18’ and 90” this hull will be a perfect base for the kind of build I want to do, I just don’t want to have any seriously unpleasant surprises
Pic posted of the boat. I understand the amount of work involved I am simply shopping for a blank canvas type of hull like the aluminum Starcraft guys use
Consider the hull to be completely toast and needing a complete overhaul
That much I expect. Given what I’d like to do it would be better to start with something like that anyhow
no, it would be cheaper and better to by a boat that is running with an outboard already.
however its your time and money
Ayuh,..... Welcome Aboard,...... I'd sooner think that pronounced hook is from rotten stringers, 'n the hull sittin' on an ill fittin' trailer for years,.....
No hull, should have a hook in it, as it'll never plane off properly,.....
Chris1956
So you are going to replace a 225HP+I/O motor with a 115HP outboard? I would expect performance will suffer somewhat. Yo will save about 700# of weight though.
KJM
What do you mean by "hook"? Last year I converted mine to an OB and have no regrets. I went from a merc 165 to a yamaha f90. If by hook you mean the keel is curved up then walk away!
Muskytek
Lots of hulls have hook molded into them from the factory 🤷🏻‍♂️
Muskytek
Yes correct.
A 115 tiller with possible 140hp V4 down the road but no more than that.
38-40mph top speed I’m fine with. I just want something to get on plane and stay there
Ayuh,..... Only if the manufacturer wants the bow, to plow,....
The last few feet of the bottom of the hull, should be straight,.....
Where is there a 19’ 90” wide fiberglass fishing boat with a tiller for less than 50k??
dont know. thats up to you to look.
doubt you will find a 19 foot tiller boat, most will come with remote steering and controls.
you would be better off looking at a blue fin or other brand of boat vs an early 80's boat with rotten stringers/transom/etc.
