reavesga
- Joined
- Feb 14, 2010
- 165
Engine is running ok, but at idle there is some vibration. I checked my compression. #2 is 100 psi which is low. Oil in the cylinder brings it right up to 125 psi. #3 is low at 85 psi and oil has no impact. So the guess is valves. I learned how to do the compression check from the forums so here is the question. If I pull the head and or replace the head that should take care of #3. What do I need to do to replace the rings? Just pull the oil pan and then work the cylinder out? What size rings? Should I re machine the block and if so what do I tell the machine shop. Trying to keep the budget under control vs installing a reman engine. Honestly she fires right up and runs great from 1000 rpm on up, just at idle she is rough. I know both of these problems are not going to go away so based on 30-50 hours of use each season is it something to do now or do I have a few more seasons to go?
