Re: Chinewalking?
Asking if your boat is chinewalking is kind of like saying "I don't know" to the doc when they ask if the defibrillator in your pacemaker ever went off.....You will definitely know! Chinewalking is much scarier than what you described.
You most certainly are experiecing a different condition, and at the speeds you are at then tabs should be able to help. First try loading the boat or shifting weight around diferently. Also verify that the rudder trim tab (I believe your outdrive has this) is there on the anti-cav plate and is adjusted properly. All said, make sure all steering components are in tolerance.
Chinewalking is when a boat is way up on plane, past plane actually and just on the pad in the back and it starts bouncing back and forth from one sponson (edge of transom) to the other. It happens when a hull's safe operating speed is exceeded, which with most hulls usually won't happen until 55+ mph. It is a very unsafe condition and means slow down! Some claim to be able to drive thru it, but the boat is telling you it does not want to play anymore.
