Chocolate milk spooge from exhaust?
ShoestringMariner
I just noticed a bunch of chocolate milk looking spooge coming from the exhaust of my 1976 650 Merc. Last time I was out, we trolled through about 20L of fuel. I never opened it up to top speed. Could this be from loading or not running up to temperature?
I checked the lower unit oil and it is brand new, all three plugs look decent except the bottom one is slightly discolored. Just a little darker and a little wetter.
it also never ran better. Trolled slow all day with only one brief act up.
​​​​​​​Thanks in advance
unburned fuel. use the throttle and open it up
tommarvin
Ensign
No disrespect Aritha F got to love her.
This isnt the lower unit,gear lube you wont know if its leaking until you change the 100 % synthetic stock marine gear lube "aka" amsoil. Or do a pressure /vacuum test.
This is your head gasket leaking water into the cylinders,please dont run the motor until you replace the head gasket, do a compression test/leak down test.to be sure, there is a trogue inch pounds order, #1,#2,and so on.Better get the mercury manual,that walks you through it step by step, and a inch pound torque wrench from HF tools
You need to get a head gasket first.clean the old gasket material off well. you got this.
Chris1956
Of course, he doesn't have a removable head on that motor....
You might check your fuel pump diagram for a slight leak. That would allow raw fuel into the water.
Ahhhh.....no.
ShoestringMariner
Whoa, confused here! Am I getting pranked?
wouldnt water getting in kill the fire in that hole, cause terrible running and show up on a plug? It seriously never ran better. The cold snap and 55degree water seemed to agree with it(??)
thanks Chris1956, I will look into it.
I’m hoping it’s nothing needing deep digging immediately. It’s getting a refurb this winter. Hope to use it until seasons end (another 4 weeks)
on two strokes, if you dont run them hard after hours of idling, the extra fuel/oil that isnt burning gets into the exhaust, mixes with water and becomes the chocolate puddin you have shown.
older two strokes are more prone to this with a straight pre-mix vs oil injection (motors need less oil at idle/low load)
your fine, go boating, use the throttle a bit to bring the temps up after you idle along trolling. no need for a WOT blast, however bring the revs up to about 3k (under load) for about 3 or 4 minutes to clear it out.
you could also use a kicker to troll
ShoestringMariner
Thanks again, yes a kicker is planned for the future when funds allow
if you watch craigslist, you can find good deals this time of year. you may have to drive a few hours, however mid 80's kickers are about $150-$200
tacx
+1 for what Scott said .Just unburned fuel in the exhaust from a lot of ideling. I have a 1970 merc that will do the same thing if i troll for long periods and dont open it up going back to the dock.
Tom
