The manual is on the way. I have a '87 (or '86?) 6 cyl 90 hp merc. When cold it doesn't want to start. I pump the fuel bulb until hard, push the key in to choke, and advance the throttle. No good. I found the choke activator switch inside the motor. When I hold this button with the ignition on, in about 10 seconds the fuel bulb will go soft, and when I pump it back up, it fires and runs fine. Am I doing something wrong with the key- choke switch? Also when the motor starts to kick, the starter will not hold its engagement (bad solenoid?). The battery is fully charged, and a meter on the (running) battery shows 12.80 Volts. Once the motor gets running, it runs fine and starts on the first try. This is a great site and I appreciate any help you can give. <br /><br />Thanks,<br /><br /> G
