Re: Choke on every start
Thank you for all the replies!! And I apologize for the delay. I've only had the motor for a couple months now, and when I first got it I didn't have to use the choke every time to start. Sure at first, if it had been sitting for a few days or so I had to. I realized that it was lately that I had to choke every time.
On Thursday I took the boat out for a spin, and I did have to choke to start.. I also noticed that it ran slightly rough at idle. I didn't think anything of it. So, I took some family fishing for the weekend and after running the boat for a while, it died on me when I went to slow down, to idle speed. Then I had a heck of time getting it started.
Once I got it started, it would run for a couple seconds and then die. I took the fuel pump off, checked the lines, and checked the pressure of the bulb; everything was fine. But, if I immediately throttled the motor up from the throttle rod connecting the carbs it would run fine at higher RPM's, but die at idle. I began adjusting the Needles and got it to where it would run at idle and not require choke. But, it now runs very rough at idle. I am also topping out at 3200 RPM's while cruising; can't seem to get anymore out of it. When before I could get 4500 easy. I also noticed that at idle it runs much smoother with the hood off.
Is all of this because of carb needles? Do I need to adjust more? I recently cleaned the carbs, so there shouldn't be any 'gunk' in them.
Thanks Everyone!
