Backround
1973 Johnson 85HP 2 cycle and 16ft Glastron
My boat and motor run well, but I want to educate myself on the choke.
There are two chokes on my boat. One is on the motor (manual) and one is below the start key, toggle,(sticker says full choke). These do the same thing, right?
It seems the choke on the motor(manual) works better then the automatic choke when starting. The automatic choke connects to some type of actuator. Is the actuator starting to fail and where canI buy it.
There is also that warm up lever on the shifter. How does that work?
I typically pump the gas bulb, pull up the warm up lever ,full choke and turn the start key. Once warmed up put choke back.
Thanks for your help
