Re: Choosing paint that i an spray on???
I have used both Interlux Briteside and Petit Easypoxy. They are both 1 part epoxies and are in the same price range.
I have had better results with the Easypoxy. It seems to level better. The Briteside had a tendency to dimple. Note, that this was using a ROLLER. It also may have been a temperature/humidity issue. With that said, and I am by no means a painting expert, but I find the Easypoxy a much more forgiving paint for a novice such as myself. I have also found that with proper surface preparation, this stuff will adhere to several different surfaces. I have used it on fiberglass, plexiglass, aluminum and zamak. I have yet to see a chip in anything I have painted.
I have not tried to spray the Briteside, but I have sprayed Easypoxy with my Wagner sprayer to coat some rail fittings. The results were really good.
I imagine with an professional air sprayer you will get spectacular results from either Briteside or Easypoxy.
