Chris craft 283 distributor
Re: Chris craft 283 distributor
Bondo, in the past, some of the 4/6/8 and trim adjustments were done with a "transmitter"
the gauge is still a basic volt meter, and the circuitry is basically a frequency to voltage converter.
to answer the OP's question, no, you can not run the tach without the transmitter. you should invest in a new set of gauges.
