ChrisCraft 20 Speedster prop question?
Vetteguy59
I recently purchased a 2006 Speedster. It has a 4.3L 225h.p. engine with a 14 3/4 x 21 3 blade stainless prop. Anyone out there with the same configuration - what prop are you running? I only had it on the water once since purchase and the boating season has ended on the upper Mississippi so I can't get it on the water til spring.
Welcome
Don't know which prop but if you know what WOT RPM's are we could give you an idea if the prop is correct
Welcome aboard.
Need to know the RPM's and speed you were turning when you had the boat on the water, in gear, going as fast as you can go with the throttle mashed so hard your arm hurt.
