Well I found my 1940-50ish bubble lights but now I need to change out some of the bulbs. These are a screw in style candelabra/mini light E-10? The strand is the old #1 wire return, so if the bulb goes you are checking each bulb for continuity.
But here is the question, 9 bulb string they do not make the bulbs anymore so I need to source them locally (E -bay will take to long).
120vac divided by the 9 bulbs is 13.3--The bulb I can get is a 14.9V 0.2 amp and I need a minimum 5 watt bulb are these going to work?
