Chrylser 75 HP rebuild - is it worth doing?
geason
Have the chance to upgrade my chrysler 1974 45 hp with a lower unit i just replaced all the seals in and works great but slow for the boat to a newer chrysler 1981 75 hp with a cylinder with weak compression. What is the actual possiblity of redoing the weak cylinder on a chrysler and would it be worth the time and money?
jerryjerry05
Re: Chrylser 75 HP rebuild - is it worth doing?
You need to figure out why it's weak.A bad gasket is an easy fix.Carboned rings not too hard.A treatment of Sea-Foam might do it.A scored cylinder anda bad piston a bunch more.
Pull the head and check it out.Then post your results.
These Chryslers will run forever if taken care of.The parts are still available.J
