Re: Chrysler 100hp Carbie kit
Mick: The gasket is a copper washer about 1/4 inch in diameter that sits under the brass seat. It holds in the inlet needle rubber seat and keeps it from deforming into the casting under the pressure of the inlet needle. It is a bit like the copper gaskets used on brake line banjo fittings. Usually, because of deformation it will stay in the aluminum carb casting until you fish it out with a small hook.
Yes, on any carb with a solid tipped needle and rubber seat, the gasket should be there. You do need to tighten the brass seat very tight so the copper will seal against the carb casting and brass seat. If you have not had the copper gasket and now put one in, it will change the float height so you will need to readjust the float.
In most cases the rubber seat is removable. It usually has a lip on one side and this lip goes in the seat, toward the needle tip. This ensures better sealing. HOWEVER: It is possible to reverse the rubber and still get good sealing if the original side was damaged or not sealing correctly.
