- Joined
- Mar 8, 2009
- 42,800
Back in 2015 I picked up a Chrysler 105 Conqueror with a 105 hp OB. Well the OB had a cracked block so could not use it. Frank mentioned before his passing that I should look for a pre 1994 Force 120 hp and swap the cowling. In looking I found what I thought was a 140, but might just be a later model 125 because of the ignition.
The 105 has a leg which is 3.5 inches shorter then the 125, and the 125 uses the newer prop and leg.
So today I'm trying to take the 125 apart to look at the water pump, change lube, impeller and see what I have to work with. Removed the prop nut and the prop is seized to the shaft. Removed all the bolts (I think), cotter pin and the leg will not come off. I can wiggle it, but something is holding it. Removed the bolts holding the exhaust cover, but it is hung up in the bottom corners only.
The 125 has trim but pivot pin is also seized. So the 105 is in good shape and could swap the motor to the 105, but then I have the old style leg and hard to find props.
So need suggestion how to get the parts off the 125 and anything else ya'll may think of
