I have a "project" 105 hp (model 1059BD SN 2222). I believe this to be about a '76 vintage. Not sure as to the extent of problems with the engine, but thought I would pull the L/U to replace the water pump impeller. There was no water in the oil, but the seals all need replacing, so I decided to pull the entire L/U apart. My question surrounds the method by which the pinion gear is secured to the drive shaft. At teardown, the pinion nut was loose, and shows signs of working on the "thrust face", but it hadn't fallen off. There is a tapered roller bearing pressed onto the pinion, and there is another tapered roller just below the water pump. The upper bearing is prevented from moving up on the driveshaft by a retaining ring (circlip) around the driveshaft. (The bearing is still a press fit.) I have a Seloc manual (and a Clymer for Force), but nowhere is there an illustration of this particular arrangement or assembly instructions. During a "dummy build", at 40 in/lb torque on the pinion nut, there is already excessive drag on the driveshaft, as the tapered bearings are being driven together, and the nut is still 1-2 threads out of safety. Do any of the Chrysler/Force Guru's have any suggestions?
I will thank all those who ponder this in advance!
