Chrysler 105hp difference between the year of 1976 and 1978.
liusigou
My motor year is 1978 and online there is a motor of 1976. I want to know if there are a big difference between 1976 and 1978. I want to buy the 1976 as a spare parts
Also can the propeller of 1976 be used in my boat of 1978?
Thank you
jimmbo
I think the powerhead is the same. The Lower unit completely different, and the props do not interchange.
liusigou
Nordin
The different is the 1976 has a 2 piece gearcase and the 1978 has a 1 piece.
Sorry but do not know if they are interchangeable. Know that you can put the 76 engine block to the 78 leg/gearcase and vice versa.
Frank A, who knew all of this has unfortunately passed through.
1976 has a beltdriven distributor Magnapower Motorola ignition. The 1978 may have the Magnapower II ignition.
These two ignition system are way different.
liusigou
How about the propeller. The guy has a spare propeller. Can this propeller of 1976 be used in my boat of 1978? Thank you
The 76 prop will not fit the 78, I have an older with the two piece leg. My block is cracked, but Frank told me that I could use a 1994 or older force motor and my cowling would swap. The two piece leg is a larger drag then the one piece
jerryjerry05
boatsdotnet. Mercury Motors. two sections to choose from.
​Use the top and open the Chrysler tab and you can find the 76 there,
Open it it in 2 windows and you can compare the 76 to the 78.
