Chrysler 105hp not charging
spool
Hi Guys,
My 105 hp Chrysler doesn't seem to be charging, I've replaced the rectifier (with a known working one) and checked the circuit breaker.
the + wire from the rectifier has continuity all the way to the battery and so does the ground, when started i get 12.5V which is the same as when the engines off.
I think the stator is the issue but i want to confirm, I've read over quite a few posts and checked the service manual.
Should i get continuity between the two black wires from the stator? what resistance should i expect and is there anything else i can do to test the stator?
jerryjerry05
Re: Chrysler 105hp not charging
CDI electronics . com and outboard ignition .com both sites have test procedures for the older motors.
spool
I found the issue, there was no continuity across the stator wires, i got a second hand stator which had continuity across the wires and now I'm seeing charge voltage.
When i took the old stator off i found damage to one of the copper wires on the stator.
I'll keep that website bookmarked although i did not use it in this case.
