Eliasarmatas
- Joined
- Oct 24, 2009
- 16
Hi,
i try to change the impeler on this model Chrysler approx.1970 model 15hp.
I removed the 4 screws below ,as you said but the leg comes out only 1cm.
Where is the gear change linkage? can you help me find it? I was trying for 2hous and could not . So i posted those photos.
In the small opening when i pulled the leg a little, i saw a small screw that joined 2 rods. I removed the screw but nothing happened. The leg still will not come out. Also i canot put it back to its place.
Can you indicate what i sould do?
Thanks a lot
Elias
Hi,
Thanks a lot
Elias
