circle hook
- Joined
- Dec 6, 2007
- 271
hello i just bought a 32 ft luhrs with twin 318 chrysler inboards after doing a compression test i found 15 cylinders @ 135 to 150 psi and just 1 cylinder @ 120 psi the repair manual says 120 to 150 is right, my question in preventive maintance what could i add to the oil change to loosen up with believe is a slightly sticky ring, the motors are old and hardly used in the last 3 years thats why i am thimking a not bad but probley carbon build up on the one piston any ideas will be appreciated. I would like to see these engine run another 42 more years if take good care of Thanks Bob
