Howdy,<br /><br />I have a question for anyone familiar with Chrysler 35hp outboards.<br /><br />I am not convinced that my motor is actually charging my battery. <br /><br />The manual I have describes a procedure that stated that I need to first see if the motor keeps running after disconnecting one of the battery leads. The next step is to check that their is power (via a test lamp) to the three yellow rectifier outputs.<br /><br />Well, I ran the motor, and disconnected a battery lead. The motor did not miss a beat, so I guess the alternator is OK.<br />The next step is to check the Rectifier. The manual shows clearly a back box roughly in the centre of the motor, next to the starter with three leads out the top.<br />The problem I have is that my motor does not have anything that resembles the pictures in the manual, actually, I can't find the rectifier on this motor at all!<br /><br />Can some help me with this?<br />I need to make sure that the motor is charging the battery, can it be possible that this model does not have a rectifier?<br />Any suggestions on how to check are welcome.<br />BTW - I don't have the model handy, but am sure that it is an early model.<br /><br />Thanks in advance, <br /><br />Zep.
