Mike722
- Joined
- Nov 7, 2005
- 370
Dad has a 355HD serial is either 1654 or 1854, i forgot to write it down. What year is it?
Also, the other night the engine would not go over half throttle and then just quit. I have no spark on either plug. I am assuming, until I can get the flywheel off that the coils are bad. I also found the flywheel was rubbing a black ground wire on the right hand side.
Dad swears that the last time he could not get the motor running he found the heat sensor broke off and the only way he could get it going was to tape the sensor back together. The overheat circuit seems like a simple ground when overheating, to either ground the IGN out and/or ground path for a horn.
Will the engine run without the heat sensor hooked up and does anyone know if and where I can order a different sensor?
Thanks for all your help
