chrysler 4.4 hp spits and sputters all the time?
steelespike
Re: chrysler 4.4 hp spits and sputters all the time?
Typically spitting and sputtering is an indication of a lean condition.
could be as simple as adjusting the low speed mixture.
thanks
I played with the mixture and went from 1/4 turn out to 6 turns out
this helped a bit but 6 is alot, it almost fell out
Do you know what the mixture screw should be set at?
what would you do next?
i was just running the 4.4 again after cleaning the carb
it's better but not quite right the mixture is set 3 turns out and runs great under load but still spits abit in low - mid idle when spining freely
brrrrrrrrrrrrrrrspit brrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrspit brrrrrspit brrrrrrrrrrrrrrrrrrrrrrrrr
kinda sounds like that very inconsistant
STUMPED
