Chrysler 45 ignition help
I just bought a 45hp Chrysler from a friend. Apparently it was used a few times a year on a small pontoon. The motor was taken off the pontoon and stored with the remote control and cables, but nothing else. So now I have a motor and a remote control with cables but no wiring except the large guage cable that goes to the battery I assume since one side goes to the motor ground and the other to the starter. I have owned Evinrudes in the past with a plug in cable on the side and an ignition box, but this is nothing like the Chrysler. I assume the remote control has a spot for a combo start/choke keyswitch, but not sure since the hole it looks like it should go in has a black plug instead. I assume there was a seperate ignition harness to the console that is now lost. I am hoping someone could coach me on how to proceed. I guess a generic replacement choke/ignition switch and a cable with the correct guage and number of wires could be used from Lowes. The model number is 457H1M and the serial number is 1415. I know nothing else. Please help!
Thanks
unslaught
Re: Chrysler 45 ignition help
due to the extend of the ignition problems u might want to get a hold of
"seloc" chrysler outboard manual .. i got one of amazon for $33 ..
get one of the 550 page paperback ..
everything is in there ... wiring diagrams , color codings the works
solved my issues with my 45HP 1970ies :)
