I have a '67 Chrysler 55 hp with type 1 (flywheel magneto) ignition. Actually what I have is a '67 Sea King mod. VWB-19087A. It is a 35 hp but I swapped the powerhead with a '73ish 55 hp powerhead. Everything is identical (except for displacement, head and carb) and installed with no modifications needed.
Now heres where I'm baffled. I have been able to establish both TDC and 28* BTDC but am unsure where the stator plate needs to be in relation. Would I be correct to assume that with the #1 at 28* BTDC, the throttle at WOT and the tower shaft in full advance position, that the follower arm on the point should line up with the index mark on the cam? Mine does not line up. In fact it won't line up until after it has past TDC. There is not enough adjustment in the link rod to make it line up. What am I missing, should it line up at 28* BTDC or TDC? I do have a Seloc manual but can't find the answer.
