chrysler 85hp 1972 decarbonizing cylinder head /rings
oslo
Hello once again,<br />I just have two questions to ask about my Chrysler 85HP '72 Outboard Engine. I was reading one of the posts last night in regards to removing carbon buildup in the cylinderhead and rings by using Sea Foam Deep Creep. I called all the marina's and mechanique shops in Mississauga and Toronto (Ontario, Canada) to see if I could find this product. No one knew of any product that would remove carbon from a two-stroke engine. I would appreciate it if someone could throw me some leads on an alternative product I can use that performs the same way as Sea Foam Deep Creep that is sold in Canada.<br />Next question<br />How do i winterize my outboard engine for storage?<br />Thanks in advance. :rolleyes:
The Marine Doctor
Re: chrysler 85hp 1972 decarbonizing cylinder head /rings
SeaFoam is not avail in Canada due to our pollution laws.<br /><br />Mercury Power Tune will work just as well. $5.55 a can.<br /><br />There is also a product called Combustion Cleaner that will work..this you add to your fuel.<br /><br />As for how to Winterize...you can do a search on the forum...I am sure there are great posts to help you out.<br /><br />If you need anymore info...do not hesitate to ask<br /><br />marine.ron@shaw.ca<br /><br />TMD
