Hello;<br /><br />I have a 1983 Chrysler 90 HP Outboard motor. I was having trouble getting it started, and did post a message yesterday about the problem. I went out a few minutes ago to work on the motor, and, lo and behold, I noticed the choke was not engaging when trying to start the engine. You would think I would have noticed that before, especially since the carb throughts are pointing straight at me when I turn the key to start the motor, but since I know very little about outboard motors.....Duh, I think the choke works the same on just about any engine, so that is not an excuse!!!<br /><br />
<br /><br />Anyway, I put a bungee on the choke lever for the two carbs to hold the choke butterflys closed, turned the key, and boom, immediatly the motor fired up. So, I assume there is something amiss with the choking module. The owner's guide states that when the key is in the "on" position or the "start" position, the choke should be "on". But, when I turn the key to the on position, the choke module, and therefore the choke butterflys in the carburator throughts, do absolutly nothing.<br /><br />
<br /><br />The choke module is the brass colored module mounted on the engine between the two carburators. When the Choke module engages, it pulls on a lever that closes the choke butterflys. I assume that is what is supposed to happen. And then, when the engine warms up, the choke module should open those two choking butterflys. This is what I assume is supposed to happen. If I am incorrect, please someone inform me in this post. <br /><br />
<br /><br />Anyway, I am thinking the problem is either in the module, or in the key switch, or the wire that goes from the key switch to the module. Could I test that module by directly touching the hot side of the battery to where the green wire going to the module hooks up on the module. I don't want to damage the motor if at all possible. I would disconnect that green wire first. <br /><br />Any help on this from the Boat Motor experts on this board would be appreciated. <br /><br />Matt<br /><br />
<br /><br />
