Chrysler Flooding & Poor Running
Sanka22
I have a question I'm new on the whole boating thing I recently bought a 1988 bayliner Capri with a 125 force at the beginning it would not stay running on idling I mess with that and now it stays but my carburetors get flooded really bad and I get a lot of smoke and motor does not go faster than 15 mph I checked the floaters but they seem to be working right I noticed that my choke does a soft click but does not closes the butterflies could that be causing the carbs to flood and the motor not run as it suppose to?
GA_Boater
Sanka22 Welcome aboard.
Moved your posts out of an old thread to a thread of your own. To see how to start new threads click on Forum Help in the sig below and look at How to ask a question / Create New Topic.
That will get you going.
On your problem; The carbs probably need to be rebuilt. Not sure if your motor has a choke or primer system. Hopefully other members will have more advice for you.
blackd
Chokes open do not cause flooding. My first guess is the needle valves are sticking open causing the flooding. Clean the carbs.
These are very simple and relatively easy to clean. Get a can of carburetor cleaner. Remove the carbs from the engine. Begin taking them apart by removing the fuel bowls. If there is residue in the bottom of the bowl it is likely that some has migrated in to the carb's small openings. Clean the bowl. Next remove the main jet and the tube in which it is located. (Some carbs use the main jet to retain the fuel bowl.) The main jet may not show any dirt, but the small opening in the tube are likely to be partially blocked. Spray with carb cleaner and it may take a small sewing needle to clean these small openings. If you haven't already, remove the floats and the needle valves. Then take the idle jet and idle adjusting screw out of the cartb. Spray each orifice/opening liberally with carb cleaner. Let dry. Replace the needle valves and floats, then while holding the carb upright activate the float with your finger while observing the needle valve. If it hangs up while the float is pushed up then re-clean the needle seat. If it continues to stick you might need to replace the needle valves.
This whole process should take ~1-2 hours. Double that time if this is your first time. This simple cleaning process will often solve most carburetor problems. While starting the cleaning carefully remove the gaskets to re-install later. If they are damaged or damaged in the cleaning order a gasket kit.
I'm sure I missed a step or two, but they will be obvious once you get into your carb. The main point is that cleaning the carbs is not a complex process, so don't be afraid of it. It is also something so common that buying old motors usually comes with caveats to clean the carbs first...
pnwboat
First thing you should check on your motor is compression. That will tell you if the rings/pistons and cylinders are in good shape. If you do not have good compression, there's not much you can do to get it to run well.....other than getting it bored and install new pistons and rings.
jerryjerry05
The fuel coming from the front of the carb??
Reeds would be my first guess.
​Do a compression then a spark test.
Post the results.
Then check the float level.
Does the squeezie stay hard when you pump it up?
