Shawn211_ont
- Joined
- Jun 10, 2001
- 2
If anyone has an old chrysler manual I need help here!! I have a 1979 55hp Chrysler outboard. I have been told the torque for the head bolts is 225 In.Lbs (19 Ft.Lbs). In my oppinion this sounds way to low. If anyone Knows the correct torque it would be appreciated, If this is similar to you're engine's specs, let me know, if this is an average torque spec for typical aluminum block Marine engines then I'd be comfortable using the 19 Ft.Lbs. Thanks....
