Chrysler Sea King 15hp Lower Unit Fill/Drain screws
smalltime
I have a 15hp Sea King, model #vwb52118a and I need the fill/drain screws and washers for the lower unit. Problem is, I can't find them in any parts catalog or here online?
I need them within a week, so I'm hoping someone can help me. Thanks a lot!
jerryjerry05
Re: Chrysler Sea King 15hp Lower Unit Fill/Drain screws
The fill/drain screws are pretty standard. Any American outboard,the screws should fit.
Yamahas are smaller.
JB
The top plug is the Vent, the lower one is the Drain/Fill. They use gaskets, one time use only. It is helpful to use the right terms so that you use them correctly.
I agree with JJ. Pretty standard, so you should be able to get them through about any Outboard Dealer. Be sure to get a supply of replacement gaskets.
smalltime
Ok thanks. I appreciate the guidance.
