Re: Chunk out of my Skeg
this is like a tail on a plane or bird , you be ok , skeg will stop your left and right motion , so you can go a streight line . check make sure you did not damage the prop area shaft , if shaft is damaged ,you hear noise or wobble, it will cause transmission problem, but you should be ok you lost a small piece , when you make a uturn , you will not turn as fast but this is not a ski boat so no big deal .
