- Joined
- Mar 8, 2009
- 43,602
Model 1408H2D
SN 1398
YR 1982
New to me motor, and taking a 125 motor and mounting on the 140 leg
Drained the lube and it looks good. Want to replace the water pump and anything else that would be advised.
I'm guessing there is no need to remove the gear housing cover, unless something is seen when pump is removed?
Parts Diagram list a drive shaft seal and crankshaft seal. My drive shaft has only a soft rubber sleeve on the splines which can be removed easy
Where the motor attaches to the leg there is a thick runner seal where the water tube attaches when motor is bolted down. I'm unable to find this part in the parts breakdown.
SN 1398
YR 1982
