chysler70hp 1979
mustangpacecar
I have a engine that starts o.k. but after it runs for several minutes it will start missing and cutting out.can anyone please help?
Terry H
Re: chysler70hp 1979
You need to check the fuel supply. Gas tank vent, hose, bulb, fuel pump, carb. There's a plastic cover on the fuel filter that comes off with one screw that has a screen behind it that can get plugged easily. <br />It's always a good idea to check the plugs and replace if needed, Check the compression(130-150), and see if there's spark to all cylinders. This will give you the general condition of the mechanics of the motor. <br />It does sound as if you are not getting a good supply of fuel so if you need any specific info check back, or and get a manual. These problems can normally be repaired with just a little patience and quite economically...just a Thought
Terry H
I said there was a plastic cover on the fuel filter...I meant on the fuel pump, take it off and clean out the screen...just another Thought
