On a 2008 (could be an '07 or '09, can't recall) Stingray 195X bowrider with a Volvo Penta 4.3 GXi-J and SX-A 1.66 outdrive, are there any simple ways to improve engine output and performance? The throttle response off-idle is quite soft and the boat struggles to pull a ~200lb slalom skier out of the water.
My engine knowledge is from the car world so I don't know if there are options for ECU/PCM upgrades/tuning, a better air intake, etc on a boat like with a car/truck?
I did change from the original aluminum 14 x 21 four blade prop to a Turning Point Hustler 14 x 19 four blade. This seemed to help a little bit with the hole shot but maybe I should have gone with a stainless prop and solid hub instead of the aluminum / rubber combo?
FWIW, with the new 14 x 19 prop, in perfect conditions, the boat will reach a GPS-verified 48mph (78km/h) @ ~4800rpm. In reality we will never need to operate the boat over ~40mph.
*File photo attached - not the actual boat
