Re: circuit breakers and fuses
I always fuse the Hot side. See post above. If for some reason the device you are fusing grounds before the fuse, you will leave it unprotected. Once the "magic smoke" is let out of the component it will never work again.<br /><br />There are some devices that switch the ground, this is fine as long as you fuse hot. If there is an EE around maybe they can give a better technical explination.<br /><br />Safe boating to all.<br /><br />Cheers.<br /><br />emp.
